1 - 3 of 3 Posts
having just bought a new momo gear knob, thought i'd fit it in like 5mins. not to be.
can any one guide me as to how i remove the old first?????????,
Re: changing gear knob on golf? (gasman007)
pull up the trim around the base of the shifter boot, it should pop up easily. Then pull the boot above the shifter knob, you will see a metal clamp that holds the knob on, cut it. now your old knob is off.
Quote, originally posted by gasman007 »
what he said above.
You'll need to cut the shifter rod for a nicer look...or at least i had to.
The stock height with Momo knobs look funny bcuz it sits too high even at the lowest installation point. Also, u might want to get the boot adapter if u want to reuse the stock boot without it looking ugly.
http://scrdesigns.com/products/shift_adapter.html
1 - 3 of 3 Posts
