1 - 4 of 4 Posts
Converting my custom lines over to SS as we speak. Finally found the adapters, the questions comes down to the issue of line size. MC to the ABS module is easy with 1/4 line and 12mm fittings no problem -4 all the way. The lines running to the brake system are all 3/16. Question is would they be a problem using 1/4 instead as well? What would the large line cause, I know it would take more fluid in the system so I have a worry that the MC will not be able to hold enough fluid, that is the only problem that I can imagine at this point in time. Ideas? Oh the reason? I can buy the 1/4 for HALF the cost of 3/16...
I have custom SS lines and adapters. 37 degree flare.
OH YOU SPEEECIAL :D
It'll be ok.
The line diameter is sized for the modulator to work properly under ABS and VSA, that is why you never want to go smaller from MC to modulator.
1 - 4 of 4 Posts
