Re: Changing Piston Rings (ValveCoverGasket)
Quote, originally posted by ValveCoverGasket » |
when youre shopping for arp rod bolts, be sure to get the non-waveloc ones for a ford 289/302. half the price and twice as many bolts. i have them in my motor and theyve been working great.
i made a post about it with PNs and stuff if you cant find em
From what I understand these bolts "can" work but with modification only. Appreciate the tip but this is one area of the engine I don't want to have to worry about modifications.
Looking for advice on what else I should replace while I have the bottom end apart. Here is what I am thinking of.
1) JE Pistons w/moly rings - 83.5mm & 9:0:1 comp ratio
2) European metal headgasket - 83.5mm bore
3) ARP rod bolts
Maintenance Items?
1) Rear crankshaft oil seal
2) Front crankshaft oil seal
3) Additional oil seal in front of 2)
4) Upper and lower main bearing shells????? This is new to me!
- is there bearings that should be replaced at this stage?
5) Flywheel & clutch bolts
6) Balance crankshaft, rods, flywheel (after resurfacing) and clutch
The block will be properly cleaned, checked then bored/rehoned for the new pistons. Anything else you guys can think of?
