Changing Seats on alltrack question
17K views 29 replies 22 participants last post by  Ben2
#1 ·
Ive been looking around for a seat swap option, I have a 2018 alltrack s and the seats are not very comfortable after 40 minutes of driving. I have a few roadtrips planned for this year and I would like to swap in some better seats in before then. I was looking at S4 seats but I dont know if they would be plug and play. For new seats they need to be more comfortable, still have some bolstering, have heat, and be electric. I would also prefer it if they were more plug n play, not requiring a lot of new parts.
Has anyone swapped new seats into their alltrack/gsw? What did you swap in and how much better is it than stock?
#3 ·
Yeah, a few folks have done this (I have R seats in my Alltrack). Seats from the GTI, R and SEL are all pretty similar (GTI and R look to be slightly more bolstered). They're all night and day compares to the seats in the S/SE, which I found to be horrible after about 20 minutes. They're either plug and play, or you may need to re-pin a seat harness, depending on what you're swapping in. My seats didn't include air bags, so it was a bit more work swapping in the seat air bags.
Best mod I've done to the car, by far.
#7 ·
Yeah I found my SEL seats on car-parts.com, they R seats are always crazy priced, even from junkyards, since they generally know that the R is a more limited car. The SEL (which are almost identical to the R seats) seats can fly under the radar at junk yards and go for much less.
I know S4 seats will work as well, I saw someone do them and he had to swap the sliders over from the mk7 seats.
I would also go into it expecting to have to do some rewiring.
I’m not sure why some sportwagens, and GTI, and R’s have different plugs, but some seats have two plugs, some have 3, and it seems like there’s no rhyme or reasons.
My 17 S 4 motion seats had 2 plugs, a friend also had a 17s 4 motion with 3 plugs..regardless all of the wires are the same, so you just have to either repin the harness, or cut the plugs off of your own seats and splice them to the new seats. It is really pretty straightforward. I’d be happy to answer any questions you have when you get to that point!
Also, yes it’s worth it. It’s my favorite mod to date.
#6 ·
I have a bit to add to this thread now that I have been through a few rounds of seat swaps.
I started with a '16 sportwagen S 5speed. seats are terrible, shocking they would put such a cheap seat in a car of this era. its not a yugo
swapped the seats for SE leatherette. unfortunately all that I learned is that the seats are leatherette and heated but bolstering/cushion/design of the bolsters has the same issues as the far too cheap S seat. These swapped in with zero effort and were plug and play though and that is always a plus.
then got SEL seats to swap in as my initial gripe with the seats wasn't exactly solved. SEL seats are night and day improvement. they plug right in, I got full power/lumbar/etc and still all was a plug and play. and the seats are great. great for long trips, supportive, and comfortable. even was able to get the seat to sit in a slightly lower position to gain some headroom (I am 6'3")
#8 ·
The fact that the S and SE seats don't fit you doesn't make them terrible, cheap or shocking. It just means they don't fit you. Many people find them just fine, even exceptionally comfortable.
#11 ·
Having owned a 2010 GTI - 2016 GSW SEL and current 2018 - GSW SEL - I can honestly say the 2010 Leather GTI seats were the best seats I have ever sat in. But they were very aggressively bolstered and that car was not my daily driver. The GSW SEL seats IMO are exceptional for a daily driver for a few reasons. In no particular order - it is the quality - durability - support - and most importantly the adjustability vs. the S and SE seats. Was a deal breaking reason we went with the SEL trim. The quality difference is significant IMO. If this is your daily driver = Unless you are a huge individual - the SEL seats would be my recommendation.
#17 ·
6'4", 240lb, 32 years old. I would like to say i'm 'in shape' but realistically I am an ex-athlete who can still get it done when needed. Work travels making me a bit lethargic, i need to work on that.
I digress. My point being, especially for a dude on the 'bigger' side of the spectrum, i find the seats to be awesome. Supportive enough, and great for me on road trips. If I were to swap to something else it'd be primarily for aesthetics.
The cloth on the GSW s, with heated seats, is the icing on the cake. I love the combo. :2 cents:
#19 ·
On the other end of the spectrum, as a 5'10", 145 lb dude with a stereotypical "cyclists" build, I couldn't stand the stock S seats. I'm guessing I'm a few inches narrower than you in the shoulder/rib cage area, and I found myself sliding all over in corners if I was wearing a slippery jacket like a puffy or rain shell.
I swapped in some cloth GTI seats, and couldn't be happier. Cloth, heated, tightly bolstered, AND plaid. All the things I need in a seat.
I'm just happy there are enough options in the MK7 platform that most can find an acceptable seat to swap to.
#18 ·
Seat Swap to SEL
I'm interested in swapping 2019 Alltrack S front driver seat to the Alltrack SEL front driver seat for the seat tilt option. I didn't want to spend an extra $10,000 to buy a SEL with all the additional bells and whistles for just the seat tilt option.
However, when discussing with the dealer's service department, they said that the power for the SEL seat would not likely work in my S trim. They thought that the wiring difference between S and SEL seat was too different - but they didn't actually check.
Is it possible to retain the power of a SEL seat (that is, the 12 way power adjustable)?
#20 ·
Your answer is found all throughout this thread! It is very much possible and the lesson you just learned is that people at the dealer rarely ever know what they're talking about!
Sent from my Pixel 3a using Tapatalk
