1 - 6 of 6 Posts
Re: Chip? What chip? (Mk4jettaGLI)
Welcome to the Vortex.
For a VR6, I highly recommend GIAC (you will find that most people will point you in the same direction). The other option would be UPsolute.
You may find this comparison helpful: http://vr6dyno.cjb.net/
Please also check out the 24V VR6 Engine Forum and the Search.
Good luck with your decision. http://****************.com/smile/emthup.gif
EDIT: This is the comparison I meant to give you: http://homepages.vdubaddiction...t.htm
But the one above is also helpful.
Modified by sebastianjbauer at 9:26 PM 5-17-2004
it may be helpful to specify what motor you have. i'm assuming a 24v vr6. you may try the search on the 24v vr6 forum under "chip."
does anything else need to be upgraded when installing the chip... exhaust,intake,etc? how much does the GIAC chip cost? is it user installable? how much HP/torque gain on a 12v? thanks.
Modified by gr8gatzby at 3:08 AM 5-18-2004
Re: Chip? What chip? (gr8gatzby)
Quote, originally posted by gr8gatzby »
The main difficulty in installing the chip by yourself would be to attach it to the motherboard, or whatever it is called in an ECU. It's best to have a socket attached in case you want to swap your stock on back in.
The GIAC chip runs around $300. To find hp/tq gains you'd be better off to search in the 12v forum or just go to their website:
http://www.giacusa.com
The chip will benefit the gains given by an intake and exhaust but are not necessary for the chip. You'll notice good gains with it alone. Adds more "meat" to the powerband. Best way I can describe it.
Modified by Vee-aR-6ix at 8:25 PM 5-17-2004
GIAC flash install takes about 45min around 8 horsepower gain $350 for 24v vr6.
have fun
1 - 6 of 6 Posts
