i had the same problem
I just call the parts department, and they said the cigarette lighter bulb that you can't change it, you have to change the whole cigarette lighter unit. Anyone can confirm that? thanks.
this is what i did:
1.remove small oval screw covers on each side of 'center console'
2.remove each screw
3.remove rear ashtray
4.slid out rear cup holder and remove the bolts there
5.there's another bolt hidden under one of the plastic little mats in the center console
6.remove hand brake cover, lift up center console and unplug gas door button
7.now remove the front side of the console and unplug wiring
the bulb is held by a plastic "holder" that slides down the cig. lighter, i took that and went to the dealer so i was able to explain better what i needed, i went a couple of times and they couldnt find the bulb but its there they just gotta try diff. ways to find it in their system.
