I am having trouble getting my golf to start. It’s a 1.8L 16v PL engine with CIS-E. TCI-h system with knock sensor.
I was working near the ignition coil and disconnected the Terminal 15 cables from the coil to unplug the terminal 4 cable. While I was plugging back the cables I swapped cable-2 with cable-1 (see image below). Cable-1 is ignition power and Cable-2 is test lead for Termnial-1 of coil.
Without realizing I plugged the cables in the wrong location, I tried to start the car and it would crank but would not start. I double checked the cables and realized my mistake and placed the cables back in their original location. Tried to start it again, same result. Cranks and no start. What went wrong?
Then I started to troubleshoot the ignition system per the Bentley manual. Below are my results;
Ignition Switched On
When the ignition is switched on, the meter should display a reading of at least 2 volts for approximately 1 to 2 seconds, and then drop to 0 volts. If not, either the ignition coil or the ignition control unit is defective.
- The test above failed, I saw 4-5 volts and then the volts would stay at 2.3 volts after 2 seconds.
Ignition Control Unit Response to Hall Sender Signal
To test the TCI-h system with knock sensor, disconnect the knock sensor control unit harness connector. Turn the ignition on and, using a jumper wire, briefly connect terminal 12 of the knock sensor control unit connector to ground. The voltage should briefly increase to at least 2 volts.
- The test above failed, when grounding terminal 12, the voltage increased to 4-5 volts from 2.3 volts.
If either test above fails, then either the ignition coil or the ignition control unit is defective. I went ahead and acquired a new old stock ignition coil and bench tested the coil for resistance; Terminal 1 and 15 .56 - .76, result .70 Terminal 1 and 4 6500 - 8500 ohms, result 10300 ohms. Terminal 1 and 4 results are out of spec, I proceeded with the installation anyways.
After installing the new coil, Ignition Control Unit Voltage to Coil and Ignition Control Unit Response to Hall Sender Signal test pass! Voltage drops to zero after 1-2 seconds. Grounding pin 12 of the knock sensor harness raises the voltage to 4-5 volts and then goes down to zero.
With the new coil installed, no start. I proceed to double check for spark at the coil and at the spark plug cables. With the spark plugs removed from the engine and connected to the spark plug cables and grounded, I crank the engine and can see a spark on all 4 plugs (orange/yellow color spark). Not blue. Is this bad? Weak spark? Inspecting the plugs after removal, they were wet and smelled of gas. I can rule out any fueling issues.
Parts Installed and Notes;
Ignition Timing.
I pulled the dist. cap off and rotated the engine by hand until the 6 deg. BTDC mark on the flywheel lined up with the arrow on the bellhousing of the trans. Double checked the rotor with the TDC mark on the dist. housing and the rotor was about 6 deg. BTDC. Made sure cylinder 1 was up, I can see it through the spark plug hole. Since my car does not start I can not check Ignition Timing using a timing light. Is there anyway I can make sure the distributor is installed correctly and not 180 deg. off?
Anyways, this is where I am at in my troubleshooting steps. No start, just cranks and cranks and cranks. Is there anything I could be missing or overlooked?
- Ignition Coil Terminal 15, battery voltage.
- Ignition Control Module, pin 2 and 4, battery voltage.
- Hall Sender/Dist plug, negative and positive terminals, 11.38 volts.
- Knock Control Unit, Pin 3 and 5, battery voltage.
- Ignition Coil Terminal 15, 10.5 - 10 volts.
- Probe Hall Sender (dist. Pin 2) with LED light, blinks.
- new dist. cap
- new dist. rotor
- new spark plug cables
- new old stock ignition coil
- cleaned all grounds
- fully charged battery
Ignition Timing.
