Re: CIS-e runs like crap after installing new fuel filter (Cheshire_Cat)
it definately sounds like after you replaced the filter, the car is no longer getting the gas. Its possible some debris entered the fuel dizzy? (hope not) or the fuel filter is simply no good even though it was new? take it out again, and try to blow thru it, it should be extremely unrestrictive. any lines get kinked? Defective check valve? The filter should only go in one way, AFAIK the bolts are of different sizes. I highly recommend the large fuel filter over the small dinky one. I had that small one in my car, and it did the same thing you describe, could barely get the car to go, replaced it, and all was good.
Cheers!
Cheers!
