Clink on this link to view the video of this Turbo Z28 Camaro...
http://www.youtube.com/watch?v=FYFV9sqW3Ew
This is a 1992 Camaro 25th Anniversary Hardtop TTA-Z28 (TTA-Z) with a complete 1989 Pontiac Turbo Trans Am (Buick Grand National style engine and transmission) drive-train with 57k original miles
Options include: Power windows, power locks, key-less entry, ice cold air-conditioning, AM/FM Stereo. The drive train assembly is complete from the Turbo Trans Am (TTA's had similar to GNX engines and transmissions with their own design for heads to work on F-bodies that performed better then GN heads) with engine, turbo, transmission, cross member, rear end, computer, wiring harness and TTA dash with working instruments. This swap of the TTA driveline into this F-body was performed properly. This Camaro is in exceptionally clean condition. This TTA-Z Turbo Camaro has always been well cared for and always garaged. This Camaro handles excellent, shifts great, gets great fuel economy and has a lot of power. It is a pleasure to drive and it is in show quality condition.
Drive-line ::
:: 3.8L TTA (Buick Grand National) engine (52k miles) with Intercooled Turbo
:: TO4B 60-1 Stage 3 .63 Turbo built by Limit Engineering, Inc
:: Fully polished Turbonetics compressor with waste gate port on exhaust housing
:: 52mm duel control waste gate - with boost lines on both sides of the spring
:: "Joe P" Manual boost controller
:: 37 # Injectors
:: Adjustable fuel pressure regulator
:: Walbro 255 fuel pump
:: Duttweiler inter-cooler necks (2)
:: 10.4 mm Taylor 409 race spiro-wound spark plug wires
:: Nitrous wet system (75 hp shot jets installed)
:: 200-4R transmission with shift kit
:: 3" up inlet pipe
:: Flowmaster exhaust system
:: Weld-in sub-frame connectors
