1 - 15 of 15 Posts
I'm looking for a relatively lightweight solution for adding a sub to the 97 bose system I have currently in my car
I'll be comming off the real speaker level outputs
I'm thinking class D for it small current draw
I'll be mounting a 10" sub in a custom fiberglass box on the drivers side behind the wheel well
band for the buck/ weight/ current draw are important to me
"bling" is not
please feel free to sujjest any subs too http://****************.com/smile/emthup.gif
Re: Class D ampo recomendations (VReihenmotor6)
You should be able to get an Alpine MRD-M300 for about $150 or cheaper on clearance/ebay (M301's just came out). They put out >300W RMS (mine was rated at 330), have a small footprint, and only weigh about 6 lbs. You can go cheaper, but $0.50/Watt isn't too bad.
Subs are pretty subjective, of course. I'd go listen to some
Just stay away from the really cheap stuff. Hope that helps...
Re: Class D ampo recomendations (nik54)
hey that does look nice
I wasn't seeing any for less than 189ish
any hints on where I might find it cheaper?
Quote, originally posted by VReihenmotor6 »
Sorry, I thought ebay would be cheaper by now. A local electronics chain had them on closeout for $177. I guess that's pretty close to "at cost".
I'll second the e-designs recommendation. I've heard some good things on elemental designs--especially bang-for-the-buck--on some of the car audio forums. Check out forum.elitecaraudio.com. There's a few good reviews over there.
Discussion Starter · #7 ·
thanks for the infor guys, please keep it comming
I'm getiing a yellow top used this week and will be moving my battery to the trunk as well and running power wires so I'd like to do the amp/ sub when I do the trunk
that looks nice
whick one of the 3 woofers in the 1st combo would be best?
the one with the 10 in it
that is what you are looking for, right?
Discussion Starter · #9 ·
Re: Class D ampo recomendations (2.ohh)
Quote, originally posted by 2.ohh »
oops, I'm stupid
I thought they were tuned to different frequenceys or something
Way to go! http://****************.com/smile/emthup.gif
Keep us posted on the install!
I did order it
did they give you an estimate of when they are going to ship out?
I think it was pretty much jully 1st ish
yeah, i just wanted to make sure they were still shipping around then.
1 - 15 of 15 Posts
