Re: (jtmoe)
it's very easy and effective. WI systems do the same thing with good results.
I noticed when I replaced the head on my 16v that the coolant softened up the carbon. When I first pulled the head the carbon was rock hard and caked to the piston. A bunch of coolant dumped into the cylinders (no I didn't drain the coolant
) and it was a month before I put the car back together. When I went to wipe up the coolant I noticied that the carbon was sludge-like and wiped off very easily. Because of that I had zero visible carbon in my engine when I put it back together.
I did the vacuum line into water trick on my 89 rx-7 (I didn't have cats on the car so I wasn't worried) and it bumped my compression up from 95 to about 105 psi. It also evened the numbers out a little. For those of you that don't know, rotaries have much different compression numbers. For my altitude with that engine 105 psi is really good.
