1 - 4 of 4 Posts
Discussion Starter #1
when i push in my break pedal mostly at slow speeds like under 20mph i get a click sound. what could this be, could it be a problem? hasn't affected breaking at all.
on a side note just because on one check the automagic fourm. i have a hard **** from 2nd-3rd with my 5-speed tiptronic. why could this be? and i want to do a fluid change so is there a DIY for it and what fluid is best to use.
Re: click sound when i hit the breaks (mystthebird)
Something like this was happening on my mk3 Golf, the pads were kind of loose and changed position (kind of clicked) when I stopped. Don't know if it's the same situation but something to check out.
Re: click sound when i hit the breaks (garm)
It's the brake pads, they're not seated properly. Put some new rotors and pads on my Volvo a couple weeks ago and had the same problem.
Discussion Starter #4
so the fix is as simple as taking the pads out and making sure they are seated right. because this started about 2-3 days ago but i got my breaks changed like a month ago.
1 - 4 of 4 Posts
