1 - 8 of 8 Posts
How do i know if the blower motor in my climate control is no good? Is it known to fail?
I had a burn resistor, so i was using the max speed for a few days, and i'm afraid that might've burnt it.
I've already checked all the fuses and the metal contact
How could i check if the blower is no good?
Thanks
Re: Climate control - Blower motor question (gomer)
pull apart that half of the dash, then find the blower. turn it on, and check resistance as well as voltage at the output shaft.
-Greg
Discussion Starter · #4 ·
Re: Climate control - Blower motor question (Strictly Gravy)
it's not behind the glovebox?
1990 VW Corrado, 2002 Audi allroad, 2017 VW eGolf
if a '93 is the same as a '90 then it is behind the glove box. mine went bad but you could hear it when you turn it on past #1. it would growl something fierce. it's kind of a b!tch to get out though if you do have to replace it.
An "acquaintance" of mine swapped everything from a newer Corrado dash into his Jetta Coupe, and the fan motor et al was right there.
Its not necessarily right behind it, its a little behind it and below it, more towards the pass side door.
-Greg
Discussion Starter · #8 ·
got it....thank you guys http://****************.com/smile/emthup.gif
1 - 8 of 8 Posts
