Ok, I have heard a lot about the transmission problems with this car, let me know if any of you are experiencing the below.
1) I will be costing along and then will hit the gas to go. When I do, a slight cluck happens before it goes. It does not happen every time, but it is quite annoying, and can't be good. It sounds like the transmission disengaged and then reengaged while everything else is moving, if that makes any since. And by no means am I pushing the accelerator hard, I can just lightly press it and the above happens.
2) I will have steady pressure on the accelerator, say going up a hill etc, and then will go to let off the gas. I then here a slight noise that sounds like air being released (sounds similar to the gas suspension when you go over a speed bump). Sometimes it sounds like it is coming from the pedal and sometimes from the engine. I can't figure it out. It could be the turbo, but it even happens at low RPM's.
I will take it into the dealer, but I hate taking these occasional problems into dealers. They never seem to fix them.
Even with the little problems I still love the car. What is it about us VW guys?
Thanks!
Thanks!
