Unless there is an obvious adjustment at either the pushrod on the pedal for the clutch master cylinder or an adjustment on the slave cylinder puchrod...Then no. And I'm fairly certain there is not anadjustment at all...Most hydro clutches have no adjustment.
What do you mean the clutch is at "the end" of the pedal? Referring to the upper end or near the floor?
If its now at the upper end of the pedal, its likely back to where normal engagement would be OR the clutch is worn out. It was being hidden by your slave cylinder going bad, or a system that was not fully bled. A leak or system with air in it will lower the engagement point on the pedal toward the floor. So maybe once you put in a new slave and got a good bleed, it brought the pedal to where it is supposed to be...Which would be further up in the pedal travel. I wouldn't worry about it unless the clutch start to slip.
If your engagement point is near the floor, could be still air in the system (being the simplest fix)
