Second. What happened to it? The slider is available from PartsPlace in MI, and I have seen the main bushings for sale all over.
cheers,
Douglas
cheers,
Douglas
It's damaged. The new transmission didn't have one.No junk yards around? I could ship you one from Texas!
What is wrong with the one you have? Can it be fixed? or "fixed"?
Yeah its the stretch one. Bolting downwards on transmission side. Underneath the air box.How does the bolt look? Most of those are stretch bolts and are supposed to be replaced. I will say I re-use them and have had no issues. What bolt are we talking about here btw? On the trans mount? Mount to body, mount to bracket?
Hey. I was using the other transmission. And from what I remember, mine was really good.How does the bolt look? Most of those are stretch bolts and are supposed to be replaced. I will say I re-use them and have had no issues. What bolt are we talking about here btw? On the trans mount? Mount to body, mount to bracket?
Body close to the bumper sideHow does the bolt look? Most of those are stretch bolts and are supposed to be replaced. I will say I re-use them and have had no issues. What bolt are we talking about here btw? On the trans mount? Mount to body, mount to bracket?
I thought maybe 30 lb torque. Would be a good start with blue lock nut glue for bolts.How does the bolt look? Most of those are stretch bolts and are supposed to be replaced. I will say I re-use them and have had no issues. What bolt are we talking about here btw? On the trans mount? Mount to body, mount to bracket?
These are the transmission and motor bolts for both side?![]()
Engine Mount -OR- Transmission Mount Installation Hardware Kit - Per Mount
Replace your one-time use bolts with new hardware for a proper install. Use for engine mount or transmission mount.www.ecstuning.com
I will only replace the bad ones. I'll keep the rest for later. I'd like to replace all top bolts going into the frame and brackets. The breaket holding the engine and transmission bolts look ok. It's the 4 top ones I'm more concerned with?I thought I'd replace all. Just to be on the safe side. The bolts going into the transmission and engine looked ok. It's manly the ones on top that look bad.
I was thinking the same thing. Just use different bolts. Then I read so many people dropping there motor.I don't think I have it in me to spend that on bolts. I am of the understanding the stretch bolts are good for less error in the installation process. If I am relying on myself to make sure the bolt is tight enough, I am okay with that. The beetle I just bought had grade 8 bolts on the engine and trans mounts. Probably what came with the VR mounts.
