Bolts will last long enough, if taken care of.I don't remember what I had factory. I'm running the hardware BFI sent me when I bought their mount kit forever ago. Factory bolt still in the dogbone mount tho, no issues thus far even under heavy boost.
3 bolts going into the transmission 16mm and the top part of the mount holes for the 18mm. Then I need to put the new bolts going into T bone mount. All new boltsHey started the engine mount bolts. I have the car up.
I just finished putting in the old mount from my other transmission.
Do you guys have all the torque specs. For the mount going into the transmission and the 2 18 mm ones going from the top thanks View attachment 145054
Sounds like you got the problem sorted out already but I'll still throw this out there. I'm running an oil pan gasket, not the messy sealant they used from factory. Way easier install and no mess to clean up. They're like 10 bux (Fel-Pro) brandView attachment 145119
This is a oil pan I bought from a different dealer. This oil pan matched the one I originally have.
I bought the wrong one from UroTuning..... My fault!!!!
I was hoping to have just a single piece. Know I'm seeing a leak on my new pan?
Am I to wait and see if the oil is coming from somewhere else.
Or dose those bolts on the new pan need tightening?
The sealer I put around the pan to motor looks good. I will triple ✔.
I put an even layer of caulk around the pan like thermal paste to a processor in a computer.
That's a heads up to anyone doing this task!!!!!!! You don't want anything passing into the engine, just a reminder!
Hey Tom.Sounds like you got the problem sorted out already but I'll still throw this out there. I'm running an oil pan gasket, not the messy sealant they used from factory. Way easier install and no mess to clean up. They're like 10 bux (Fel-Pro) brand
