1 - 10 of 10 Posts
Discussion Starter #1
Does anyone have a picture of how the clutch cable arm weight (that metal block) is mounted . I think i lost a piece/or forgot how it mounts . FOr a 2.0 transmission . Ive searched for hours http://****************.com/smile/emthdown.gif
Re: CLutch cable arm weight ([email protected])
The plastic end of the clutch sheathing sits in that mount on the top of the trans....then the end of the cable itself (which should have a little flat tip to it) goes through the clutch arm, through the middle of the rubber block, and threads through the side of the metal weight. The metal weight should have like a little metal track on it, with a hole on the side just wide enough to thread the flat end of the clutch cable through.
Disregard the inch and half of spacers, I just haven't had time to go buy a manul adjust cable yet, and disregard the duct take....I guess I watched to muc red green
<img src+http://img.auctiva.com/imgdata/9/9/8/2/9/6/webimg/216192357_o.jpg>
Discussion Starter #7
Re: CLutch cable arm weight (aaaaaaaaaa)
this is the arm the cable connects to.
This is the weight im talking about
the project
Discussion Starter #9
Re: (aaaaaaaaaa)
Quote, originally posted by aaaaaaaaaa »
Isn't that middle picture the 20# weight that sits on the cross member below the engine?
I cant remember !
1 - 10 of 10 Posts
