1 - 6 of 6 Posts
Like its notchy.........when i depress the clutch very slowly, when teh car is on or off, i can feel a little notchyness when i let the clutch out slowly......Is this normal? sometimes iot does it and sometimes it doesnt.
Re: CLutch feels weird...notchy is the only way i can describe it (JimmPTL)
is it a stock clutch,
if so a clutch can do that if oil gets on it and if the clutch disc is shot
if you have like a stage 3 clutch then it is normal
Re: CLutch feels weird...notchy is the only way i can describe it (vwdriver92)
yea its stock. But how would oil get on it? how would it make the clutch pedal feel notchy when coming back up?
it might be oil if not it is blown cause I had the spring fly apart on it and that dorks it up, oil can get on the disc 1 is their is a hole in the side of the tranny and 2 if a rear main seal blows, those aren't likey, I would say your clutch is on it's way out, I not sure about hydraulic clutch cause I never blew out one but on my cable clutch trannys the car would shutter and after awhile the pedal would not come all the way back up, I think a hydraulic the pedal would still be their
ok sorry after reading your original post you said the pedal feels notchy with the car off, when I read it I though you meant while drivein, I am not sure what it would be off the top of my head,
Discussion Starter · #6 ·
yea i need a clutch/ more of a flywheel job soon, but might as well to teh clutch. I think i have uneven flywheel wear.
1 - 6 of 6 Posts
