Quote, originally posted by Nico. » |
fine tuning. |
Quote, originally posted by gti.jon » |
Also, how much does a clutch replacement usually go for (mk4 gti vr6)? Thanks in advance. |
Quote, originally posted by koston. » |
I.P.M. in Redmond - they warrantied the clutch work that another shop did, and they finish on time. I'm not a fan of having my car held hostage by a shop that can't mange their own schedule. Modified by koston. at 10:36 AM 3-23-2010 |
Quote, originally posted by MEISTER » |
http://forums.vwvortex.com/zer...06162 http://forums.vwvortex.com/zer...10318 |
Quote, originally posted by mechsoldier » |
That depends, how many miles on your car because if you're near 120,000 miles then you need chains and guides too. So your car came with a dual mass flywheel from the factory which is pretty expensive and weaker than a solid flywheel. The best bet would be to get a solid flywheel conversion. That's going to give you better performance and it'll be cheaper. Name: 02M 240MM STAGE 1+ CLUTCH KIT W/ FST STEEL BILLET FLYWHEEL FITS VW MK4 Golf Jetta 02-04 2.8 24v VR6 W/ 6SP, (NON R32) that's on this page here. http://www.fourseasontuning.com/?category=10 Then have a shop install it. I'd call all the shops in the FAQ for a price quote. |
Got about 85,000 miles on the car now. The link you sent is for 24v I have a 12v. I saw some other clutch kits on that site though. Any other good kits with a lighter single mass flywheel? I saw one on ECS for about $440. Thanks for all the input ![]() |
Well the 12v single mass flywheel isn't really all that heavy. The deal with the dualmass is they weigh like 24 lbs. |
That depends, how many miles on your car because if you're near 120,000 miles then you need chains and guides too. |
Quote, originally posted by 97VWJett » |
I would do it regardless of the mileage if the transmission is coming out, more cost effective. |
True but we know how it goes in this economy. 40,000 miles is 3 years for most people, maybe four. I try to get customers to do it but if you don't have the cash and your clutch is dead what do you do. |
