Suddenly the clutch pedal started to vibrate when the clutch was slightly depressed, and the vibration varies with the rpm, and is slightly more pronounced whent the tranny is in gear when the clutch is depressed. Also a rattlly squeaky sound is heard. The clutch does not slip ( 131k miles, 5 spd 2001 Jetta GLS 1.8T) I believe the throw out bearing is dying. I plan to replace the clutch with a Stage 1 kit when I replace the throw out bearing. My question is, should I replace the "guide sleeve" while I have the tranny and clutch removed ?
Some times its refered to as the "Release bearing guide sleeve W/seal, part # 02A141180A"
EP
EP
