my neighbors 97 2.0 has a clutch issue that i cant exactly pinpoint
all of a sudden the clutch will no longer fully release, it will allow you to shift gears while moving but when stopped the only way to get the car in gear is to shut off the motor.
i have checked the clutch cable, pulls just as much as mine which is problem free. also fully lifted the clutch arm with a jack and no difference was made
also pulled off the green cap on the end of the trans and removed the bearing/rod and replaced them with known working pieces. the original rod in the car was slightly shorter and more worn than others i compared it to. and after swapping the pieces no difference was found.
im thinking that the problem is in the clutch itself, possibly the release plate?
i just need a little bit of advice and other options to try since we dont want to pull the trans unless we know that is the only option left.
btw the car has about 200k on it clutch has about 30k trans has somewhere around 100k
thanks for the help http://****************.com/smile/emthup.gif
