Coast in neutral or down shift ?
617 Views 12 Replies 13 Participants Last post by  EPilot
Coast in neutral to a red light and stop ? Or should I be downshifting as I approach the light ?
Car's manual says not to "idle" the engine whenever possible 'cause it's bad for the Cat Converter - ??? So downshift it is ?
See less See more
Status
Not open for further replies.
1 - 13 of 13 Posts
Re: Coast in neutral or down shift ? (r8r)
I usually downshift so if the light turns green while I'm still slowing down, I'll already be in the right gear and I can just punch it!
See less See more
Re: Coast in neutral or down shift ? (djGolfGTI)
save your brakes and downshift
Re: Coast in neutral or down shift ? (Blue Flame)
quote:[HR][/HR]save your brakes and downshift
[HR][/HR]​
it should be "Save your tranny and brake"; replacement brake components cost a lot less than replacement tranny/clutch components. It is unecessary to downshift when you know you're about to come to a complete stop at a red light -- just pop it into neutral and let off the clutch and brake. Same goes for stop signs and such.
Re: Coast in neutral or down shift ? (Deception)
Also remember that if you simply downshift, your brakelights will not show to those behind you as they would if you put it in neutral and use the brakes. I always do the latter because it's both easier and safer.
2
I usually down shift once, say from fifth to third, then let the engine brake me till I need to binders.
This doesn't work if you tailgate the car in front of you
As far as no brake lights goes, well thats why I have insurance
See less See more
Re: Coast in neutral or down shift ? (Green-Golf)
I put it in neutral and brake... unless I'm feeling aggressive that day and want to hear my exhaust growl... then I downshift
2
Definitely coast in neutral. I'd rather replace brake padshttp://****************.com/smile/emthup.gif than syncros and tranny components. http://****************.com/smile/emthdown.gif
Of course, I'm known for being hard on my brakes anyway.
[Modified by KonigGTI, 9:13 AM 2-6-2002]
See less See more
i just lay off the gas and clutch and let the car slow down by itself, and use the brake when needed. then i shift to neutral right before i come to a stop. shifting to neutral immediatlely seems pretty unnecessary and really counterintuitive if you think about it. the car is going to roll faster if you're in neutral.
IB4TL - this was a topic a few days ago. Surprised the lock monster hasn't locked it already.
P.S. - I usually coast in neutral when coming to a stop.
Re: Coast in neutral or down shift ? (downbylaw)
quote:[HR][/HR]i just lay off the gas and clutch and let the car slow down by itself, and use the brake when needed. then i shift to neutral right before i come to a stop. shifting to neutral immediatlely seems pretty unnecessary and really counterintuitive if you think about it. the car is going to roll faster if you're in neutral.[HR][/HR]​
Re: Coast in neutral or down shift ? (steez)
When coming to a light I usually pop in the clutch and leave it in gear. If I have to stop I use my brakes. Theres no need to downshift.......why put your engine under uncessary stress?
1 - 13 of 13 Posts
Status
