ive disabled tpms using 19 CAN gateway since i put my set of winter steelies on this past thanksgiving. all i did was uncheck the checkbox for tire pressure monitoring, nothing else was changed. my specific question is the following:
1. after doing so is the below BOLDED code normal? (the gateway list is also posted below.)
Friday,24,November,2006,20:48:30
VAG-COM Version: Release 607.3-UD
Chassis Type: 1K - VW G/J Mk5
Scan: 01 02 03 08 09 0F 15 16 17 18 19 1C 22 25 36 37 3D 42 44 46
47 52 55 56 57 62 65 69 72 76 77 7D
VIN Number: WVWEV71K97W023848
Address 01: Engine
Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Coding: 0403010A18070160
Shop #: WSC 01279
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Coding: 0021122
Shop #: WSC 01279
Address 08: Auto HVAC
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Address 09: Cent. Elect.
Part No SW: 3C0 937 049 AA HW: 3C0 937 049 AA
Component: Bordnetz-SG H45 1402
Coding: 078F8F214004150000140000001400000028770B5C0000
Shop #: WSC 08272
Part No: 1K1 955 119 E
Component: Wischer 310506 020 0501
Coding: 00038805
Shop #: WSC 08272
Address 0F: Digital Radio
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Address 15: Airbags
Part No SW: 1K0 909 605 Q HW: 1K0 909 605 Q
Component: 5L AIRBAG VW8R 033 7900
Coding: 0013644
Shop #: WSC 01269
Part No: 1K0 959 339 D
Component: BF-Gewichtsens. 006 0006
Address 16: Steering wheel
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002022
Shop #: WSC 01279
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments
Part No SW: 1K6 920 973 A HW: 1K6 920 973 A
Component: KOMBIINSTRUMENT VDD 1610
Coding: 0007203
Shop #: WSC 00000
Address 19: CAN Gateway
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Coding: 7D0F03600F000000
Shop #: WSC 01279
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 109
Mileage: 3634 km
Time Indication: 0
Date: 2000.00.00
Time: 20:43:54
Address 1C: Position Sensing
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0002
Address 25: Immobilizer
Component: IMMO VDD 1610
Address 42: Door Elect, Driver
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0967
Coding: 0001077
Shop #: WSC 01279
Address 44: Steering Assist
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Address 46: Central Conv.
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Coding: 139006885103083F2D04058FB0080A04889C00
Shop #: WSC 00000
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
00896 - Trunk Lock Unit (F256)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 149
Mileage: 3634 km
Time Indication: 0
Date: 2000.00.00
Time: 15:27:50
Address 52: Door Elect, Pass.
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
Shop #: WSC 01279
Address 55: Xenon Range
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
Shop #: WSC 01279
Address 56: Radio
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio PM6 165 0018
Coding: 0040401
Shop #: WSC 01279
Address 65: Tire Pressure
Component: RDK 0420
Coding: 0100101
Shop #: WSC 01279
End
Sunday,26,November,2006,13:16:35
Gateway Installation List: 1K0 907 530 H
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0011
Obviously 19 is related to 65 in this case. Its my impression that disabling tpms via the CAN gateway only prevents the light from coming on the dash but the TPMS system remains active, is this correct? I have no TPMS indicator light on my dash (which is good) and I have no warning indicators in the MFD (which is good).
All I would like to know is if the above codes are normal after disabling TPMS via the CAN gateway.
P.S. Please ignore the trunk lock code, that happened after driving my car with the hatch not properly closed all the way.
Thanks.
Address 01: Engine
Shop #: WSC 01279
Coding: 0021122
Shop #: WSC 01279
Shop #: WSC 08272
Coding: 00038805
Shop #: WSC 08272
Address 15: Airbags
Coding: 0013644
Shop #: WSC 01269
Coding: 0002022
Shop #: WSC 01279
Coding: 0007203
Shop #: WSC 00000
Shop #: WSC 01279
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 109
Mileage: 3634 km
Time Indication: 0
Date: 2000.00.00
Time: 20:43:54
Coding: 0001077
Shop #: WSC 01279
Shop #: WSC 00000
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 149
Mileage: 3634 km
Time Indication: 0
Date: 2000.00.00
Time: 15:27:50
Coding: 0001076
Shop #: WSC 01279
Coding: 0000003
Shop #: WSC 01279
Address 56: Radio
Coding: 0040401
Shop #: WSC 01279
Component: RDK 0420
Coding: 0100101
Shop #: WSC 01279
End
Thanks.
