1 - 10 of 10 Posts
All of the following:
Address 01: Engine
Controller: 06A 906 018 J
Component: MOTRONIC M5.9.2 HS V05
Coding: 00000
Shop #: WSC 01317
11 Faults Found:
16519 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit Malfunction
P0135 - 35-00 - -
16525 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit Malfunction
P0141 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
16521 - Oxygen (Lambda) Sensor B1 S2: Signal too Low
P0137 - 35-00 - -
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
P0300 - 35-00 - -
P0303 - 35-00 - -
P0302 - 35-00 - -
Readiness: 0010 0001
Car will not run properly at all. Obviously,
Car will not run. Starts and I can keep it running but eventully stalls, and the fuel pump relay clicks rapidly when it suddenly cuts out for a second, then catches, then does that again, then stalls. I can keep it running by keeping it reved but it will not drive. The engine cuts out when Im trying to move and eventually just dies. I have changed: both O2 Sensors, Crank angle sensor, coil, MAF, Fuel pump relay, ignition wires within the last 8-10K, plugs at that time, and cant find any vacuum leaks. Any ideas?
Re: Codes, O2 Sensors, Misfires, Etc (slyez)
Check fuses i have seen blown or missing fuses throw a check engine light with many faults like your 02 sensor faults, but did not cause car not to run. I would also check for possibly a bad cat causing misfires and causing it to die. If you have not yet check air filter for possible mice nest starving it of air.
Discussion Starter · #8 ·
Re: (dirtracer901)
I was planning on getting a FP gauge this afternoon. Where should I hook the gauge up to in the fuel system? Is there anywhere that will not require permanent modifications? What is the proper fuel pressure?
Discussion Starter · #10 ·
ordered a FP tester. Back to parts swapping....Try Cam sensor next. Dont have high hopes for FP problem as the engine just cuts out suddenly and then sometimes catches suddenly. like fuel cut or ignition cut.
1 - 10 of 10 Posts
