1 - 7 of 7 Posts
Discussion Starter #1
Posting this to find out if a problem being experienced on Skodas is being found on other VAG cars with the same system and maybe a warning to those looking at coding to tread very carefully indeed as the usual protections of autoscans and adaption maps before and after will not protect you with this problem.
This concerns the new 2016 Model Year cars 1-2 months old with the new MIB2 headunits (Amundsen and Columbus on Skoda, Discover and Discover Pro on VW)
Coding certain items (we now believe in 5f) will cause unrelated menus to disappear from the head unit. Coding done on an item is successful so it is not the wrong thing being coded.
The adaption maps being taken prior to any coding are not showing how the car actually is (judging by the menus functional on infotainment at the time) this mis-read map is being coded to the car when other items are coded resulting in corruptions in the controller.
Adaptions are being made that result in corruption of the head units and loss of menus that do not appear in VCDS log files so it is impossible to re-trace steps as you actually have not made those steps.
RossTech have not responded to queries about this from several people for over a month now so I would be very careful about using VCDS on a MY16 car with the high-end nav units until this is sorted.
Oh dear. I helped a guy that had used a fake dongle on a 2011 CC with the same issue. The car was totally corrupt and the scan said nothing. But I managed to solve 99% of the problems by copy paste long coding from a facelift 2012 Passat station wagon. Later on he went to the shop for service an they uploaded new code online from Germany. Car is fine now.
I am trying some coding on a 2016 Audi Q7 tonight in the 5f module. Maybe I should not.
Discussion Starter #3
All the issues have certainly been with genuine leads and we are all verified VCDS owners using 15.7.1. The problem is that in addition to making changes you did not do and did not want it will refuse to let you code the items back properly.
We have identified some of the offending adaptions in 5f but when you change the value what it should be it says "coding accepted" but the value stays as before and the function stays broken.
Personally I would not touch 5f on a 2016 model year car until this is sorted. Over a month and nothing from RossTech so I would not hold my breath.
My mission is to try activate the Webasto auxiliary heater as parking heater. In Q7 4L it was not necessary to go throug 5f as in the Touareg. If so, I will let the customer decide wich way to go.
I´ll report back later on.
This new Q7 4L does not have the auxiliary heater. All touaregs and Q7 I´ve played with prior to this MY 16 have it, that´s for RoW and sold in Europe.
Impressive car by the way. And look at the elapsed time for autoscan.... the 15.7.1 had trouble communicating with the modules.
Monday,26,October,2015,19:21:58:51824
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
Workshop Code: 666 12345 054321
VIN: WAUZZZ4M6GD003600 License Plate: XXXXXX
Mileage: 4424Km Repair Order:
Chassis Type: 4M (4M2)
Scan: 01 02 03 06 08 09 15 16 17 19 28 2B 36 42 44 52 5F 69 6D 81
A5 AC
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-CRTC) Labels: None
Part No SW: 4M0 907 401 HW: 059 907 309 B
Component: 3.0TDI EDC17 H45 0003
Revision: 91H45---
Coding: 2A2A4032053E050335080000000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114M0907401 001007
ROD: EV_ECM30TDI0114M0907401.rod
VCID: 66FB89E399ADBD0EC7-8032
1 Fault Found:
9645 - Reductant
P20E8 00 [096] - Pressure too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 4182 km
Date: 2015.10.21
Time: 08:51:50
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: None
Part No SW: 4M0 927 158 J HW: 0D5 927 156 H
Component: 0D5 30TDIRdW H03 1007
Revision: --H03---
Coding: 100000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMALX52011 002009
ROD: EV_TCMALX52011.rod
VCID: 3B4D0897B2AFD0E648-806E
No fault code found.
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 4M0 907 379 K HW: 4M0 907 379 K
Component: ESP9 Premium H08 0514
Coding: 249830B230A20A99D6A45891187D529AE6A6D2240C0C506B1A184A5967654B
ASAM Dataset: EV_ESP9BOSCHAU736 011006
ROD: EV_ESP9BOSCHAU736_AU73.rod
VCID: 3FB57C87A6B7CCC664-806A
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4M0 959 760 E HW: 4M0 959 760 E
Component: MEM-BFS 008 0014
Serial number: 00000147921920
Coding: 001833000001B2410000210101010000110000313100000000000000000000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
ROD: EV_SCMPasseSideCONTIAU736.rod
VCID: 3A430D93BD95E9EE53-806E
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 4M0 820 043 K HW: 4M0 820 043 K
Component: Klima Zone 4 H52 0060
Coding: 6618003C5544401102220180800000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 2D6936CF7CDB4E56C6-8078
Slave 1:
Subsystem 2 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000000283720
6 Faults Found:
262193 - Position Sensor in Left Side Vent
B10E3 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 79
Mileage: 3416 km
Date: 2015.09.29
Time: 13:19:17
262194 - Position Sensor in Right Side Vent
B10E4 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 79
Mileage: 3416 km
Date: 2015.09.29
Time: 13:19:17
262195 - Position Sensor in Left Center Vent
B10E1 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 79
Mileage: 3416 km
Date: 2015.09.29
Time: 13:19:17
262196 - Position Sensor in Right Center Vent
B10E2 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 79
Mileage: 3416 km
Date: 2015.09.29
Time: 13:19:17
262197 - Position Sensor in Rear Left Upper Body Vent
B10E5 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 79
Mileage: 3416 km
Date: 2015.09.29
Time: 13:19:17
262198 - Position Sensor in Rear Right Upper Body Vent
B10E6 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 79
Mileage: 3416 km
Date: 2015.09.29
Time: 13:19:17
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 8W0 907 063 G HW: 8W0 907 063 G
Component: BCM1 MLBevo H12 0215
Coding: C2501942C10800CD010D0611583F0CF9130331018000000000000000A000160100410022125601
ASAM Dataset: EV_BCM1BOSCHAU736 014003
ROD: EV_BCM1BOSCHAU736_AU49.rod
Slave 1:
Subsystem 1 - Part No SW: 4M1 955 119 A HW: 4H2 955 119 C
Component: WWS536 140901 042 0792
Serial number: 150303090332
Coding: 1BC7F7
Slave 2:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 20281747
Coding: 02006E
Slave 3:
Subsystem 3 - Part No SW: 4M0 941 531 N HW: 4M0 941 531 N
Component: E1 - LDS H05 0007
Serial number: 05 07 2015 00041896
Subsystem 7 - Part No SW: 4M0 857 511 A HW: 4M0 857 511 A
Component: Y7_Innenspieg H08 0002
Serial number: GX1CE105051511520084
Coding: 030000
Subsystem 8 - Part No SW: 4M0 947 135 BE HW: 4M0 947 135
Component: J528-Dachele H13 0080
Serial number: Q00010531
Subsystem 14 - Part No SW: 4M0 907 705 HW: 4M0 907 705
Component: J866-EVLS-SG H03 0040
Serial number: WA120436000012251594
Coding: 020100
Subsystem 20 - Part No SW: 4M0 925 301 B HW: 4M0 925 301 B
Component: SL-Q7NF/AU736 H09 0006
Serial number: 00000000000000003709
Address 15: Airbags (J234) Labels: None
Part No SW: 4M0 959 655 HW: 4M0 959 655
Component: Airbag10.44 H50 0081
Serial number: 003L10004ZDY
Coding: AACCF0D80C80000058F650F3C00C00000000
Shop #: WSC 54867 001 1048576
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_AU49.rod
VCID: 78C7D79BC3193BFE65-802C
Seat belt tensioner; left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 4M0857705D0127P00275
Coding: 88001B
Seat belt tensioner; right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 4M0857706D0133P00154
Coding: 88001B
Crash sensor for side airbag; driver side:
Subsystem 3 - Part No SW: ----------- HW: 442 060 505 15
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00AB193B853C28A
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 4 - Part No SW: ----------- HW: 442 060 505 15
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00AB193B854140
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 5 - Part No SW: ----------- HW: 442 0B0 905 15
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700A11A48244C42%
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 6 - Part No SW: ----------- HW: 442 0B0 905 15
Component: SideSensor_Pr 1C7 0148
Serial number: 35277009F1A4824403FD
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 7 - Part No SW: ----------- HW: 442 0C0 405 15
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B91A48231F227
Coding: 2D2D2D
Crash sensor for front airbag; front passenger side:
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 405 15
Component: FrontSensor_P 1C5 014A
Serial number: 3567500B91A4823032A3
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 9 - Part No SW: ----------- HW: 442 0C1 205 15
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500B11984751B22-
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 10 - Part No SW: ----------- HW: 442 422 904 15
Component: PedPSensor_D2 21E 0887
Serial number: I0M8U00AD17C323343CM
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 11 - Part No SW: ----------- HW: 442 422 904 15
Component: PedPSensor_P2 21E 0887
Serial number: I0N8U00AD17C3231516E
Coding: 2D2D2D
Central Sensor XY:
Subsystem 12 - Part No SW: ----------- HW: 410 201 401 15
Component: CentrSensorXY 1C8 0108
Serial number: I0O7800AB1656925A0E7
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4M0 907 129 HD HW: 4M0 907 129 HD
Component: Lenks.Modul H11 0008
ASAM Dataset: EV_SMLSKLOAU736 006008
ROD: EV_SMLSKLOAU736_AU49.rod
VCID: 79C1D29FF81322F61A-802C
Address 17: Instruments (J285) Labels: None
Part No SW: 4M0 920 790 HW: 4M0 920 790
Component: FBenRDW H12 0240
Coding: 042401D0388000080B03E9603000200000000000
ASAM Dataset: EV_DashBoardAU736 001020
ROD: EV_DashBoardAU736_AU49.rod
VCID: 6CEFFBCB8741875E91-8038
1 Fault Found:
16777022 - Control unit for information electronics 1
U1054 00 [008] - No Communication
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 137
Mileage: 3725 km
Date: 2015.10.11
Time: 12:54:54
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4M2 907 468 A HW: 4M2 907 468 A
Component: Gateway H13 0078
Revision: 3C010050 Serial number: 5043C00FE15416
Coding: 0301000100000F407F000000005900324C920007080000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 002040
ROD: EV_GatewCONTIAU736_AU49.rod
VCID: 365B19A3898D0D8EB7-8062
Subsystem 4 - Part No SW: 4M0 951 523 HW: 4M0 951 523
Component: J453 MFL H06 0002
Serial number: 20150421111947 RD105
Subsystem 5 - Part No SW: 8S0 915 181 HW: 8S0 915 181
Component: J367-BDMHella H10 9041
Serial number: 4653706503
1 Fault Found:
16646149 - predictive route data
B1630 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 128
Mileage: 3773 km
Date: 2015.10.12
Time: 16:51:30
Address 28: HVAC, Rear (E265) Labels: None
Part No SW: 4M0 919 158 C HW: 4M0 919 158 C
Component: Klima Zone 2 H52 0060
Coding: 000000000000000100820080000000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
ROD: EV_AirCondiFondBHTCAU736.rod
VCID: 35591EAF948B0696BE-8060
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 15000000407001
Coding: 8800000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 325325B365E511AE9B-8066
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS 008 0014
Serial number: 00000147921826
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4M0 959 593 D HW: 4M0 959 593 C
Component: TSG FS 005 0036
Serial number: 0000149469562
Coding: 005C9A005E00048200013082
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 3D49068FACBBDED676-8068
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4M0 909 144 E HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H17 0003
Revision: -------- Serial number: 0000787260
Coding: 90040001000100
ASAM Dataset: EV_EPSVWBSAU736 006014
ROD: EV_EPSVWBSAU736_AU49.rod
VCID: 31512ABF60E32AB6E2-8064
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4M0 959 592 D HW: 4M0 959 592 C
Component: TSG BFS 005 0036
Serial number: 0000149471931
Coding: 005C9A005E00048200013080
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 3C4F0B8BB7A1D7DE41-8068
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4M0 035 036 HW: 4M0 035 036
Component: MU-P-LN-EU 041 0221
Serial number: A288D0FB000821
Coding: 013706010000000013110002000A00102F001BE501700100DE
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU73.rod
VCID: 62F395F37585C12E2B-8036
Media Player Position 1:
Radio Tuner - Digital:
Subsystem 2 - Part No SW: ----------- HW: -----------
Component: ------------- --- ----
Serial number: --------------------
Engine Control Module 2:
Subsystem 3 - Part No SW: ----------- HW: -----------
Seat Adjustment Driver Side:
Subsystem 4 - Part No SW: V03 959 802 CA HW: -----------
Component: ECE 2015 --- 0118
Air Conditioning Compressor:
Diesel Pump Control Unit:
Door Electronics Driver Side:
Subsystem 7 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9FJ40079E
Brake Assistance:
Subsystem 8 - Part No SW: ----------- HW: -----------
Interior Monitoring:
Subsystem 9 - Part No SW: ----------- HW: -----------
Sound System:
Door Electronics Rear Left:
Subsystem 12 - Part No SW: ----------- HW: -----------
Subsystem 13 - Part No SW: 4M0 919 615 D HW: 4M0 919 615 D
Component: ControlUnit_P H14 0160
Serial number: 09051500000000000025
Subsystem 14 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1010
2 Faults Found:
5726 - Volume Control
U11B9 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 139
Mileage: 4173 km
Date: 2015.10.20
Time: 20:34:19
6696 - Instrument Cluster Control Module on Optical Bus
U10C0 00 [008] - No Communication
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 131
Mileage: 3697 km
Date: 2015.10.09
Time: 15:26:39
Address 69: Trailer (J345) Labels: None
Part No SW: 4M0 907 383 D HW: 4M0 907 383 B
Component: Anhaenger H18 0208
Revision: 9A001002 Serial number: 0368191707
Coding: 0110000202010000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_AU37.rod
VCID: 335D20B79AFF18A690-8066
Subsystem 2 - Part No SW: 4M0 907 811 HW: 4M0 907 811
Component: G820 KNWINSEN H18 0019
Serial number: 3117
Address 6D: Trunk Elect. (J605) Labels: None
Part No SW: 4M0 959 107 HW: 4M0 959 107
Component: HDSG-Modul H12 0143
Revision: -------- Serial number: 29991817600000
Coding: 0090
ASAM Dataset: EV_DeckLidCONTIAU736 001010
ROD: EV_DeckLidCONTIAU736_AU49.rod
VCID: 70D7EFBBAB6963BEAD-8024
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4M1 713 041 D HW: 4M1 713 041 D
Component: GSM-LL H07 0066
Revision: 0L0D5012 Serial number: 20150402001658
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 267BC9E3592D7D0E07-8072
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 4M0 907 217 B HW: 4M0 907 217 B
Component: BVS H11 0023
Coding: 0407030600000402022023A1AD0000B400F0C010C000
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002020
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
2 Faults Found:
1123600 - predictive route data
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 141
Mileage: 3435 km
Date: 2015.10.02
Time: 11:06:27
1123601 - predictive route data
Freeze Frame:
Fault Priority: 6
Fault Frequency: 52
Reset counter: 144
Mileage: 3450 km
Date: 2015.10.02
Time: 11:30:40
Address AC: Reductant Control (J880) Labels: None
Part No SW: 4M0 907 355 HW: 4M0 907 355
Component: SCR-Stg-G3H10 0003
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736.rod
VCID: 6EEBF1C3B15D754EBF-803A
End-------------------------(Elapsed Time: 06:45)--------------------------
Discussion Starter #6
I think the elapsed time is more to do with the number of controllers it is talking to, my Skoda is pretty high spec and the autoscan is consistently 6:10. Had no problem doing the coding. Each thing I did worked and the logs reflected that.
It is just that other things were done that I did not want or do and are not listed in in the logs either.
Just wouldnt touch MY16 with VCDS at the moment
I hade several "VCDS not responding" freeze frames during the autoscan.
Anyway, time will tell if there is a heater that can be unlocked and will shown in the Installation list.
1 - 7 of 7 Posts
