Re: Coil battery wire connection (slayman)
If your wires are shorting out why not replace the wires?
Or, atleast do that first since they need replacing and see if that solves your problem.
A plug wire that is shorting out can often be seen in you simply look for arcing/sparks along your wires while the vehicle is running. Those sparks mean that your spark glug in that cylinder either did not fire at all or did not fully fire causing your engine to stumble since you were minus one cylinder.
