1 - 16 of 16 Posts
ok so maybe im a Noob, stupid, or just out of the loop. But what in the hell is this thing? FAUX coilovers? FOILovers if you will?
If i read this right accroding to ECS i can just slap these bad boys on my cup kit and now i have adjustable suspension?
1. why would they only work on bilsteins...what else do they work on?
2. explain to me why more people dont use this
3. i know im missing something cuz im too excited that i can go lower for this cheap right now.
4. i miust be wrong and its too good to be true
http://www.ecstuning.com/stage....html
ECS Coil Over Kit-Front Kit
Budget minded coil-over kit that works on Bilstein shocks & aftermarket springs
Already have springs and shocks? Do you need to just raise or lower the front of your vehicle? The ECS Coil Over Add On Kit is designed to fit directly over aftermarket shocks (O.D of 1.5" or 40mm). Allows for +1.5"/-3.5” of height adjustment. The only limiting factor is your shocks &/or your wheel & tire set-up. Complete kit includes:
2 ECS Long Coil Over Sleeves (front)
2 Billet Aluminum Spring Perches (front)
2 Large Gold Anodized Billet Adjustment Nuts
2 Small Gold Anodized Billet Adjustment Nuts
1 Large perch wrench
1 Small perch wrench
Re: coilover "add on" kit for $140??? - how low do these go??? (lowitfk)
Quote, originally posted by lowitfk »
just adjustability in the front which is ghey! just get coilovers vmaxx is 699 buddy thats cheap
599
Re: coilover "add on" kit for $140??? - how low do these go??? (dubcc)
wow thats a cool idea. i have a cupkit and dont want to spend anymore money on this pig...i'm going to look into these, i just want to lower my front a little bit. http://****************.com/smile/emthup.gif
edit: says only for B5 passats and audis?
X2 EDIT: FYI, this does not work with H&R cupkits, I inquired about my personal setup...just to let you other H&R guys know.
Modified by clark w. griswold at 4:02 PM 5-11-2007
Discussion Starter · #8 ·
Re: coilover "add on" kit for $140??? - how low do these go??? (clark w. griswold)
Quote, originally posted by clark w. griswold »
ah chit, whats the difference tho. if it works on stadard shock n struts?
and im more than sure that my H&R out handles some 599 coilover system, even if it does not go as low
. I just want the front to come down a little more and these lowering caps are no where to be found and sometimes dont work....
Modified by thelettert at 3:05 PM 5-11-2007
Banned
Re: coilover "add on" kit for $140??? - how low do these go??? (thelettert)
Quote, originally posted by thelettert »
I am more than sure with 5 years of legal driving experience you have no idea what cars are capable of stock let alone lowered.
FYI, they will work with the struts though.
I ran a similar set of "coilovers" in my mkIII, and first hand experience has taught me that unless you know what you are doing, don't touch these. They are no different than a GC threaded spring kit (in terms of equipment), and if you can get a decent set of shocks, they make for a good performance suspension. You can get them to go as low as you want in the front since you have to weld the sleeve to the shock body for proper installation while the rears are no different than any other aftermarket threaded suspension kit.
Modified by abawp at 12:45 PM 5-11-2007
Banned
Re: coilover "add on" kit for $140??? - how low do these go??? (abawp)
id be more conserned if the struts and shocks can take that kind of drop..and adding that price to your existing cupkit, and the price you pay for shipping from ECS you might as well get koni Coilovers
Elvir
vmaxx is $599
Banned
Re: coilover "add on" kit for $140??? - how low do these go??? (the.good.gli)
Quote, originally posted by dubcc »
599
Quote, originally posted by the.good.gli »
vmaxx is $599
Reading > You http://****************.com/smile/emthup.gif
Discussion Starter · #16 ·
Re: coilover "add on" kit for $140??? - how low do these go??? (Lowjack)
oh god thats scary ^^
i figured it was too good to be true. damn ecs getting my hopes up. i guess the front will have to be slightly too high till i find some lowering caps or some cash for real coilovers
1 - 16 of 16 Posts
