Re: (importtuner)
In that case your choices are far more limited. There are the H&R dunebuggy kit which is 1in lower and taller than stock, the Bilstein PSS kit which is 45mm lower frt and 40mm lower rear, and can get the car to just about stock height, and then there is the Ground Control kit. You'll be able to get more appropriate spring rates that fit what you're looking for and since its all custom you should be able to get stock height and lowered as well. The GC kit is a sleeve over kit though, so you'll have to purchase shocks as well, unlike the other two.
