1 - 4 of 4 Posts
2011 Jetta Sportwagen S 2.5L; 2021 Hyundai KONA SEL
I'm not sure about 2014 models (mine is a 2011) but you might have Front Struts and Rear Shocks + Independent Coil combo setup - so you wouldn't have rear "struts" per say hence you can't find "coilovers".
I have no idea what spec sheets you're referring to, but If you would have looked closely at all of those sets, then you'd realize they include the "solid" shock absorbers and the individual "coils" for the rear.
You purchase a "coilovers" set, but the rears in fact are not actual coilovers.
I hope that helps. Good luck
1 - 4 of 4 Posts
