Hello i have a problem i am new to turbo charges engines and am working on getting the bently for this car.
what i have
2004 b5.5 passat 1.8t wagon
108,000 miles
awm engine / manual trans
totally stock
(all service done at VW dealer till i bought it @ 104,000)\
Here is the issue, on cold start up i have a consistent "tapping or knock" form the valve train. once the cold start ends and engine drops to a normal idle the "tapping or knock" becomes intermittent. After warm up noise becomes nonexistent. warm start up noise nonexistent. i have tried to pinpoint the noise and found it centered around the valve train.
-timing belt, tensioner, and water pump changed @ 105,000
-valve cover gasket @105,000 no evidence of oil sludge
-plugs checked and @ appropriate gape
did fill up last tank with regular
normally use premium however was unavailable @ the time
Thank you for any help,
what i have
108,000 miles
totally stock
