Re: Cold weather stumbling - '67 Bug w/1600cc single port (jackr)
Cold weather.. Wow.. I moved from the nice warm So Cal, to Northeastern Oregon.. I was running a Zenith 32NDIX carb, on my dual port motor. It didnt have heat risers on the manifold, and after only a few minutes of driving, I would literally get a block of ice on the carb. That would be my first thought, check out your intake manifold and make sure that your heat riser tubes are not plugged with carbon.. If they are.. You may not be getting enough heat to the carb, and it wont mix fuel and air correctly.. My car acted that same way.. My solution was dual webers. Get the carbs closer to the heads for heat, expensive, but well worth the money.. Got more power from it too.. Mileage went down a bit, but no matter. It runs excellent even when its 10 below.. Good luck..
