1 - 2 of 2 Posts
-SOLD-
Full price, sold on Vortex,
Happy new owner.
Selling my 1988 VW Fox GL wagon, SERIOUS INQUIRIES ONLY. about 102k on car
location Deale Maryland 20751
due to photobucket pictures are not straight forward.
follow this link to view the pics when i bought it.
http://s122.photobucket.com/user/Dacolino/library/88 fox wagon?sort=3&page=1
car is listed on Craigslist with some current pics, happy to send anyone pics thru texting or email.
https://annapolis.craigslist.org/cto/d/1988-volkswagen-vw-fox-2-door/6348559022.html
wagons-imported only 3 years, when was the last time you seen one clean,sorted and tuned?
I also have running and driving AEB 1.8t 150hp twincam turbo donor powertrain with 115k also available for this car.
many uninstalled rare parts see bottom
MD tagged ,
1988 VW Fox GL wagon-imported only 3 years,
-White - Paint is original.
-Corrado leather seats
-Has around 110k original miles (Body and underside are very clean)
-MINIMAL RUST, a little bit of surface rust here around the windshield and under the car, NO ROT. It's very clean, and the pictures show that.
**Engine & Drivetrain**
-Stock original shortblock
-JH heavily ported and polished cylinder head, stamped "STOKER"
-G-Grind cam
-Neuspeed adjustable cam gear
-Ported mk1 intake manifold
-Bigger TB
-Dual outlet exhaust manifold
-Dual Techtonics downpipe
-Stainless Techtonics 2" Cat back
-E30 engine mounts
-TT HD front engine mount
-New radiator
-New heatercore
-Low temp theromostat and matching fan switch
--Top end has no more than 100 miles on it, fresh valve job w/ new valveguides
-WOT switch installed on Throttle body, wired into the car and running a 16v ecm. I personally tuned the car and the a/f is perfect at WOT from idle to redline. The timing is currently set to 9degrees advance and it runs on 87 octane. It's not the fastest thing in the world but for what it is, it moves along well.
-9Q Quantum turbo diesel 5 speed trans with all appropriate linkage swapped in. EXCELLENT trans for cruising on the highway and has a close 1/2/3 gear pattern.
-Clutch installed with trans, about 25k miles ago.
-New trans mount
-Shifter bushings done when the trans was swapped out and are still fresh, the shifter feels great.
**Suspension & brakes**
NEW General AltiMAX HP less then 1000 miles old
-Bilstein Sport shocks/struts
-Vogtland 60mm race springs for a mk2 application
-NEW ball joints,lower control bushings, tie rods and alignment-she is tight.
-New strut bearings
-Rear shock mounts installed at the same time as the suspension about 25k ago
-New 24mm Master cylinder, new fluid flush
-Front brakes are 10.1 units just installed about 10k miles ago. Nice Ate pads and rotors.
-Rear wheel cylinders replaced about 10k ago, Shoes and drums were in great shape.
-Rear wheel bearings done at the same time 10k ago.
**Interior & Exterior**
-Hella H4 headlights with sylvania silverstar bulbs
-Kenwood excelon headunit -- the stereo sounds great for small sized speakers!
-Infinity kappa front and rear speakers
-Pioneer amp and 10" sub in the trunk
The car is a factory non-a/c car and at one point had an aftermarket a/c unit installed, the heaterbox that was in the car was destroyed, so I was forced to source another heaterbox. The one in the car functions and works like it should, heat is blasting hot like it should be.
Have acquired correct A/C box, and controls, Condenser.
-Wired in 16v CE-1 mk2 cluster. I was having problems sourcing another fox tachometer cluster and had a spare 16v cluster around and wired it in. Everything works as it should, and if you wanted to you could wire in MFA at a later date.
PARTS not installed
factory in bumper fog lamps
opening vent windows imported from Brazil
Interior 1/4 panels with factory additional speaker mounts
spare perfect grill, and head light surrounds
Factory A/C components
discussable items not included
Webasto drop and slide moonroof kit !!
Audi GTE oilpan (will fit the AEB)
Spare 9Q transaxle
Spare glass
there is more...
1999 Passat car w/ AEB/5spd 114K runs perfect...I bought it as an organ donor for the Fox.
contact me at mhanyi at yahoo dot com or 4436270048
1 - 2 of 2 Posts
