didn't want to start a new thread for this. just bought the ingalls camber kit but it was stocked incorrectly so waiting on the correct one to be sent... but here;s my question, do i even really need it? my alignment shop said they got to the point where they don't think i really do. reason I ask is because i've gone through 1500$ in tires in the past year alone ( two front tires wear out on the inside seem down to the radials). alignment shop says i just need to rotate more. so... question is... if i do rotate more, will my tires still wear out without the camber kit??
and if i do need the kit,
is the ingalls one ok?
tia!
:n
p.s.
I'm on H&R coils. And they've settled alot, seems like they keep settling
(installed in 04 when vehicle was purchased) but here's my numbers for my last alignment, if that helps at all...
FRONT..........................LEFT......................Right
Camber
...................... -1.0°
Cross Camber
...............................0.0°
Caster
.......................... 7.5°
SAI
Toe
..............................0.04
Total Toe
.....................................0.08°
REAR..........................LEFT......................Right
Camber
.......................-2.6°
........................-2.6°
Toe
.............................0.14
Total Toe
.....................................0.22
Thrust Angel
.................................0.06°
