1 - 5 of 5 Posts
due to the Monsoon speakers being designed to work with the Monsoon amp, you have three choices. You could find a used replacement woofer and install that. This would be the easiest thing to do. Second, you could buy a replacement aftermarket woofer (or pair and swap out both sides) but it may sound funny. The Monsoon speakers have a lower impedence than normal 4-ohm speakers and they are mounted to a plastic baffle so you'll need to make MDF trim rings. Third and hardest, you'll need to replace everything. All the speakers and the Monsoon amp. If you have no other plans to upgrade the stereo anytime soon, I recommend just replacing the speaker with a used one. You can find them in the classifieds all the time and 1 speaker should cost about $15-20.
Re: (DJKeebler)
Quote, originally posted by DJKeebler »
http://****************.com/smile/emthup.gif ya..... pretty much iether go w/ the 1st of 3rd option he gave you... if you've got ample time/money on ur hands replace everything... otherwise just find a new woofer in the classifieds or something... its not worth doing a half-ass job
Just disconnect the other rear, fade to the front, and call it a day. No need for rear speakers back there anyways. Mine haven't been connected for almost a year now, and so far I have no complaints (rear passengers included).
Re: (erobinson)
oh... didn't read that it was a rear..... ya... you would probably be fine w/ just dumping all of hte rear speakers... if you absolutely must, replace hte woofer... but ya... never go to the trouble of putting nice components in the back
1 - 5 of 5 Posts
