Re: Compression ratio of X-flow head on JH block?? (JusAnothaRabbitRacer)
Well you could run carbs if you like, but the CIS is more efficient.
I'm presently talking with my head builder about retro fitting the CIS injectors, shouldn't be a problem, just needs an insert so the old injectors fit.
Yes the crossflow flows better then a stock old style 8V head but if it's well the old head could equal it. BUt the reason I want it is becuase the intake is one the front of the head and has steeper ports, the way it should be. No hot intake ports, more power right.
