1 - 10 of 10 Posts
Does a thicker headgasket increase or decrease compression ratio? I'm thinking since it's gonna be taller, it's gonna increase stroke and increase cr. Someone tell me if I am right and if not, let me know. Thanks.
Re: Compression ratio... (A2 VW)
It decreases the compression ratio, the gasket does nothing for the stroke, that's determined by the crankshaft what the thicker gasket does is effectively make the combustion chamber bigger and that lowers the CR.
This might help you get a handle on what's happening
Compression ratio= total volume / chamber volume.
Total volume =displacement + chamber volume
Chamber volume =cylinder head chamber volume + deck volume + gasket volume
Re: Compression ratio... (ABA Scirocco)
Or put more simply, the ratio of cylinder volume at BDC over the cylinder volume at TDC. For example, a 10:1 ratio means the volume at BDC (bottom dead center) is 10 times the volume at TDC (top dead center).
Without getting into the mathematics, adding a thicker head gasket increases both the numerator and denominator equally, but not proportionally, and you end up having a proportionally larger bottom number. The result is a reduced ratio.
See, I said it would be simple.
yea the guy who is P&P my head said he will shave it like 0.060 to increase the compresion one point BUT i have a question. If i get over sized pistons later down the road will the compresion be to high with the head shaved?
Re: Compression ratio... (8v-inside)
Perhaps, if need be you can get thicker gaskets too. If you need any info about that, check with the guys in the forced induction forum they do that sort of thing all the time. It would be a good idea for you to cc your head and block to see where you are at now, that way you can make intelligent decisions based on hard numbers rather than guessing or taking someone else's word for it.
Re: Compression ratio... (jazzpur)
quote:[HR][/HR]JettaRed put it the best it could be...ive been trying to say what he just said for 3 months[HR][/HR]​
Thanks. I just wish I understood what I said.
1 - 10 of 10 Posts
