1 - 14 of 14 Posts
AIR ZENITH OB2 ---- PRO's CON's ---feedback needed
looking to get new compressor
and some said the AIR ZENITH OB2 is VERY Quiet compare to dual 480C
and they claim it is the fastest 12V air compressor on the market.
is this true ?
anyone got experience of this item ???
PRICE: $370USD
PRODUCT SPECIFICATIONS
● Motor Voltage: DC 12-Volt
● Max. Amp Draw: 35A
● Max. Working Pressure: 200 PSI
● Duty Cycle (at 72°F/200PSI): 100%
● Max. Ambient Air Temp.: 158°F
● Min. Ambient Start Temp: 40°F
● Motor Type: Permanent Magnet
● Thermal Protector: Yes
STANDARD FEATURES
● Oil-free design, non-lube piston & cylinder
● Patented interchangeable piston assembly
● Long-life, PTFE compound piston ring
● Balanced connecting rod, low vibration, low sound levels
● Direct driven motor with automatic reset thermal overload protector
● Waterproof cooling fan
● Heavy duty check valve pre-installed on cylinder head
● Stainless steel braided air hose with ½” NTP air tank fitting
● Remote mountable high performance air filter
● 80A relay with pre-wired relay socket
● Integrated 3-position mounting brackets with NYLOCK self-locking mounting hardware
Re: AIR ZENITH OB2 ---- PRO's CON's ---feedback needed (felixy69)
from what i have heard/read, these are really good. when my viar's die im getting them http://****************.com/smile/emthup.gif
Discussion Starter · #4 ·
Re: AIR ZENITH OB2 ---- PRO's CON's ---feedback needed (ryanmiller)
question is do i need 2 for 6 gallon to equal 2 480c?
here are some numbers, if these are correct, i think the dual 480C are still faster then a single one of these OB2
AIR ZENITH OB2
TANK 5gal
0 to 105psi
01:53
0 to 145psi
03:22
0 to 175psi
04:45
0 to 200psi
06:50
85 to 105psi
00:36
110 to 145psi
01:21
140 to 175psi
01:38
165 to 200psi
01:52
Modified by felixy69 at 4:03 AM 9-6-2009
Modified by felixy69 at 4:06 AM 9-6-2009
Discussion Starter · #6 ·
DUAL VIAIR 480C
5.0 Gallon Tank Fill Rate
0 To 200 PSI
5 Min. 02 Sec.
165 To 200 PSI
1 Min. 15 Sec.
Banned
Quote, originally posted by felixy69 »
well, i would hope that a dual pump setup is faster than a single pump setup. but there is no way that one 480 is faster than one OB2.
Here are the fill times for a single VIAIR 480C
0 To 145 PSI
6 Min. 02 Sec.
110 To 145 PSI
1 Min. 55 Sec.
0 To 200 PSI
10 Min. 08 Sec.
165 To 200 PSI
2 Min. 20 Sec.
Here are the fill time for a Single OB2 on a 5 gallon tank...
Discussion Starter · #9 ·
Q's about viair 495C
ViAir 495C Chrome 12V Constant Duty Air Compressor Pump (495)
The ViAir 495C chrome air compressor pump is a stunning constant duty air compressor; producing a continuous supply of compressed air even at 175 PSI! It will run at 100% Duty cycle all the way up to it's maximum working pressure providing you with a reliable, constant duty air source. It'll fill up a 2.5 gallon tank up to 150 PSI in just two minutes! This unit is completely sealed, dust & moisture resistant and is the perfrect choice for performance-driven mobile applications that require a continuous supply of compressed air.
IT SAIDS CONSTANT, DOES IT MEAN IT WONT STOP???ANYONE GOT EXPERIENCE WITH THIS??
Modified by felixy69 at 3:47 PM 9-6-2009
FV-QR
My roommate had the AZ pumps & went through 4 in 2 months & I have heard similar stories from other people with experience with them. From what I have heard I would stay away from them at all costs. I would not run their pumps if they paid me to. No one I have run into has good things to say about them. My roommate said they are really loud too. Viair is ideal!
Re: FV-QR (cigarnut81)
yes its true, they have had issues in the past with the AZ's but they are bigger and better now. I have 2 of the old ones and they fill my 8gallon fast. But the one thing i love about them the most is i can rebuild them
1 - 14 of 14 Posts
