1 - 7 of 7 Posts
Re: condensation in tail lights (BoraVR6)
could that really be the problem? will the condensation in there go away eventually? i tried to dry it out with a blow dryer but that doesn't help b/c the moisture is between two layers of the plastic that i can't get to
[Modified by NJTDI, 7:33 PM 12-2-2001]
Re: condensation in tail lights (NJTDI)
it will only go away if you are sure that more condensation is not occuring anymore. And depending on how much water is in there, it may take a very long time (also depending on how much night driving you do - heat from the bulb is what gets rid of the condensation..)
Re: condensation in tail lights (WannaCorrado)
not much at all in there......i tried to make sure everything is sealed off, it looks pretty good i think...we'll find out when it rains i guess b/c i'm afraid to spray it with the hose
1 - 7 of 7 Posts
