Now you have an iPhone and you are looking for a way to connect and listen to the radio on your iPhone. I know you are thinking to yourself that you already have a cable at home, or you would just connect your earphones to the ear piece of your iPhone, but that is not the case here. There are options out there for you if you are looking to connect and listen to the radio on your iPhone. This article will give you all the information you need to know to connect and listen to the radio on your iPhone.
First of all, you want to make sure your iPhone has a microphone installed before you do anything, so make sure that your ear bud is plugged into the headphone jack. Then attach the wire that runs from your iPhone's dock connector to the end of the ear piece that is attached to your TV. The ear bud will now be your radio to listen to, and all you have to do is put your finger in front of the ear piece to listen. You may need to use your free hand to keep the ear buds in place, because you need to keep them from getting knocked out.
To get rid of that annoying ear buzzing, you can buy one of those earbud headphones that plug into your ear hole and muffle the noise. However, with an older model, you may find that you can't find any ear buds to purchase. If this is the case, you can always find one online and have someone else install it for you. Connecting to the radio should only take a minute, and then you can sit back on your couch and listen to whatever you want. This is one more reason why you should always turn off the volume when you don't want to be disturbed. Your neighbor or your kids may be able to hear what you are listening to, so you want to make sure it is just for you.
