Not sure of the link to Connie's install... but it is really a very simple process. Just take off your bumper cover (a few bolts on the top, behind the stock grille and lower grilles, and the screws on the inside of the wheel well--and don't forget to remove the side marker lights), line up the new grilles (they have tabs with holes for the screws on the side), and screw 'em in there. You might have a problem installing the bumper cover bolts that sit behind the grille after this IF you don't have a thin screw driver to re-install the grilles after tightening up the bolts for the cover. Does that make any sense?
Just take the cover off and it's all very easy. You'll see what I mean. Good Luck.
