1 - 3 of 3 Posts
So I've have a slow coolant leak for quite a while. Assumed it was the water pump and then looked into it and looks to be the 2 coolant lines on the front of the engine and the flange on the side. Everywhere I look shows the flange for Audi A3 2.0's to be here.
IMG_0745 by jonathonhendricks, on Flickr
When I look at my flange it looks like this coolant flange. Trying to figure out if something is wrong and I need to correct it or how I got this flange.
Check it out: get some hose clamp-offs and examine the fitting. Check for cracks, etc. A few of this type of clamp will save you from draining all your coolant to check out the fitting.
1 - 3 of 3 Posts
