1 - 3 of 3 Posts
the jetta was recently taken to the dealer for a 60k and they found that the coolant level was low. they suspected a leak but found nothing. a couple of days ago, the coolant light started flashing upon startup so i checked the reservoir and found it to be a bit low. can i just add a little bit of water to the overflow tank or do i have to use the pink coolant from the dealer?
Re: coolant level warning light (enticiveblkmax)
If you only need a few ounces you can use water. Any more and use the 50/50 mix.
1 - 3 of 3 Posts
