1 - 8 of 8 Posts
How high should you fill the resevoir to? Also is it ok to us Prestone coolant from Checkers?
Lost some coolant when I installed my green top coolant sensor. Forgot to tighten the cap after I released the pressure.
Re: Coolant level (Fantomasz)
The manual says you can only use G12 is that really an issue? Or can you mix other brands like Preston?
Moderator
Re: Coolant level (Sleeper GM)
Quote, originally posted by Sleeper GM »
NO!
G12 only, the other stuff will destroy the cooling system.
How little did you put? You might have to get it flushed. I did the same thing. $99 at the dealer.
2018 Atlas R-Line; 2019 330ix M-Sport
Re: Coolant level (rs4-380)
Quote, originally posted by rs4-380 »
NO!
it says G12 on the coolant reservoir for a reason http://****************.com/smile/emthup.gif
Discussion Starter · #8 ·
Re: Coolant level (NoDubJustYet)
I only drove it for 2.5 miles and only put a quarter of a resevior of the coolant with the G12. Getting flushed right now.
1 - 8 of 8 Posts
