1 - 4 of 4 Posts
I installed a new coolant pipe on my diesel Jetta yesterday, but I have two problems with the new pipe. The pipe isn't a proper fit and will not line up with both places the original one bolted on to :confused:. The second is there is an extra outlet that is touching my oil filter.
I was thinking I could fix it by bending the pipe to align with the lower hole, but that would require me to cut the extra outlet off :banghead:. Has anyone experienced this problem, or have any suggestions?
Are you sure you have the right hose?
Pics?
+1 on right hose?
It doesn't have to be the exact same part, as long as you can make it work.
Is it leaking coolant out of the "Outlet"???
1 - 4 of 4 Posts
