Re: Coolant Temperature Sensor? (gtiglxvr62000)
make sure your car has been turned off at least 4 hrs. i had my car off for about 2.5 hrs and the coolant was still hot. i burned my hands/finger with the coolant. so make sure your car is cold before changing the sensor.
also, how long haven't you changed your coolant? If you've never, this is a good time to flush your system and refill with new coolant. After you pull the old sensor out, just let the old coolant gush out.
It's better for the system. all you need is coolant from the dealer, clips and a sensor with an O-ring.
if you have any questions, you can IM me. I just changed it last week so everything is still fresh in my mind.
