1 - 4 of 4 Posts
Discussion Starter #1
Okay so i got a corrado a couple weeks ago, the fresh air fan wasnt working...At all speed so i started to investigate by the obvious things, i look at the fuse box and i see a 30A in the slot (which is 20A according to bentley) The fuse was blown so i got a new one (20A) and then i turn the key to ON and VOILA! the fan work!
But there come the scariest thing for a VW owner...i see smoke coming out of the front grille! :what:
I immediatly turned off the power and removed the key, i got under the hood and by turning the power on again (without fan) i pin pointed the source... Its one of the 3 sensor related to the thermostat, it the yellow one and 2 pin inside were melted. I removed the fuse for now and it seem to be alright but i need to fix that since i need defrost cause its getting cold in the morning. Thermostat was changed for a 70C, new thermostat housing too. The fan hasnt worked in a while.
I need your help fellow dubbers, any infos would be appreciated!
The yellow temp sensor has 2 sensors built in.
G2
The Blue/white (pin 2) wire goes to the fuse box, then onto your cluster temp gauge.
Pin 3, brown is grounded, these 2 pins make up the cluster temp gauge sender.
F87
Pin 1 (Bentley shows Brown/white) goes to pin 8 of the FCM (assuming you still have the original 8 pin FCM).
Pin 4, Brown is grounded, these 2 pins make up the the Fan control thermoswitch.
Perhaps you have a faulty FCM which are known to get water ingress. There is no way water can egress as it has no drain holes.
The UE recall replaces the early 8 pin FCM with a later model 10 pin FCM.
Main fan can fail tool, there was a recall for the fan due to faulty materials used.
This is the TJ recall.
Getting these recalls performed by a dealer is unlikely. Many have tried recently only to be denied.
Discussion Starter #3
G2
F87
Thanks for your reply, i'll look it up tomorow to see which connection are burned and those should correspond to +/- of a sensor? And are those available at the dealer or any europart shop? And about the recall, well my serial doesnt correspond to vr6 so i doubt they would do anything :p
Discussion Starter #4
Okay so today i checked the connector to see which wire was fryed and it turn out to be both ground (pin 3/4) could it be related to a faulty main ground? I also looked in the bentley for infos on that sensor and how to change it but i was wondering if the coolant will escape when i'll remove it. Also if i have the 3rd one (brown) its for AC? but one wire is snipped out and i dont think the compressor would work anyway :/
Also can anyone help me locate the FCM?
Thanks for your help!
1 - 4 of 4 Posts
