Re: Correcting the odometer after cluster switch. (mybabyrulez)
Go find one of those fix the odometer posts or pages where they go into detail about fixing or replacing the cracked drive gears.
When you get down to the shaft, carefully file or Dremel the crimp nubs off, you can re-knick them with ***** later during re-assembly.
TAPE.
Tape all the wheels together so they don't quickly get away or you're looking for yet another cluster. The last one I did, I got it within 4k miles, decided that was close enough, I hadn't figured out the tape trick then.
The job can easily make the most dexterous among us feel as though we have ten thumbs per hand, I give the job a ten for gratification when it comes out well. Patience definitely required.
