1 - 5 of 5 Posts
Vendor
When you step into the aftermarket turbo world, boost control is PARAMOUNT. The Cortex EBC offers unparalleled boost control in an affordable package. It has the ability to take inputs from:
Vehicle Speed
Engine RPM
Throttle Position
With those inputs it can calculate what gear you are into quickly and effortlessly. The controller can be paired with a 3port or 4port solenoid which if you opt for the later, you will have much greater control and range of boost with even the lightest of springs. Want to run 3psi in 1st gear,10psi in 2nd, and 20psi in the rest? NO PROBLEM! Want to help keep surging at bay when you're cruising down the highway and need to "lightly" pass somebody, too easy! Build a map based on throttle percentage!
Save your tire tread for the twisties, curves of your favorite road course!
Boost control is programmed with your computer and quickly loaded to your boost controller with the supplied USB Cable.
It also has two Output wires...
Have aux systems to control? Nitrous? Intercooler misters? Maybe that Water/Meth kit we mentioned earlier? Set water/meth function based on boost pressure, gear position, engine speed, and also throttle position. More than a simple on/off function, this controller offers FULL progressive control of the pump duty cycle so you hit max pressure/volume when and where you need it most!
GET YOURS TODAY!
ORDER HERE!!
Vendor
So after finding my local E85 station to have accidentally had their tank filled with 93, i knew i needed an ethanol sensor!
So i contacted the Cortex engineer and he was able to successfully take the GM Ethanol Sensor Output and have it accurately display ethanol percentage on the boost controller!!
Wire it into the Analog Voltage input of the EBC, add a 10k resistor between the 12v power to the SENSOR and the signal output and you're done!!
ONE MORE REASON THIS IS AN EXCELLENT BUY!! :laugh::beer::peace::laugh::peace::beer:
1 - 5 of 5 Posts
