1 - 3 of 3 Posts
Discussion Starter #1
New here and need some guidance! 2000 vw jetta tdi 1.9 327k miles. No mods just regular maintenance and replacing worn parts here and there on this 20yr old girl!!
Driving home from work couple months back and I came around corner, got back on throttle and took off as usual. Went about 100 yards after turn and then died, I coasted a good way to be in a decent spot on side of road. Turned key off, popped hood everything seemed okay under the hood, timing belt in tact, nothing leaking so hopped back in cranked it over a few times and nothing. I towed it home and got home in dark. I Didn't tinker with it until the weekend trying to look online for a few common issues.
Things ive done so far:
-Primed injection pump, made sure air was out of lines and cracked injectors got fuel to shoot out. Cranked over and it seems like it wants to "fire off" but nothing. (crank no start)
-Ran codes with obd-2 tool and came across some bad glow plugs, replaced them and new harness.
-Replaced n75 valve
-Glow plug light would come on then go out as usual but still replaced relay 109.
-Battery went dead so its been on tender since I bled IP. I vcds scanned car and got online for some ideas. Battery tender got unplugged one day and forgot to get plugged back it so battery had gone completely dead. I had battery checked a week ago and it was bad. I replaced with new and been hooked up to tender ever since. The car seems to crank a lot better but still no bang...
I bought a vcds plugged it in and ran scan about a month ago but not %100 sure what any of that stuff means. I'm not very computer savvy but can follow directions pretty well and I'd consider myself mechanically inclined but running low on ideas. Any help is greatly appreciated. Here's my scan->
Saturday,21,November,2020,08:38:41:44591
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: License Plate: 666
Mileage: 526880km-327388mi Repair Order:
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
Mileage: 526880km-327388miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 BD
Component: 1,9l R4 EDC G000AG 2507
Coding: 00001
Shop #: WSC 00066
VCID: 53F3746832EFAA63BF1-4B1E
No fault code found.
Readiness: 0 0 1 0 1
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 HK
Component: AG4 Getriebe 01M 4606
Coding: 00000
Shop #: WSC 00000
VCID: 00598B249319E1FB523-0962
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00066
VCID: 3E2535DCA96D570B60F-4B3C
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 09 AIRBAG VW5 0003
Coding: 12345
Shop #: WSC 00066
VCID: 35372AF09C5B9453B15-4B3C
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 900 M
Component: A4-KOMBIINSTR. VDO V57
Coding: 07242
Shop #: WSC 25426
VCID: 2C010F944F11D59BDEB-5160
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0X2027956
IMMO-IDENTNR: VWZ7Z0X2027956
3 Faults Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to Plus - Intermittent
29-10 - Short to Ground - Intermittent
01314 - Engine Control Module
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00007
Shop #: WSC 00066
VCID: 70B9DBE4A3B9F17BA23-5160
1 Fault Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
VCID: 06559D3CB13DCFCB68F-4B1E
Subsystem 1 - Part No: 1J1959801C
Component: 61 Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 61 Tõrsteuerger. HL0002H
Subsystem 4 - Part No: 1J4959812C
Component: 61 Tõrsteuerger. HR0002H
8 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
00933 - Electric Window Motor; Passenger Side (V148)
62-00 - No or Incorrect Adjustment
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1JM 035 157 A
Component: Radio DE2 0004
Coding: 02041
Shop #: WSC 00066
VCID: 3E2535DCA96D570B60F-51F2
1 Fault Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
End----------(Elapsed Time: 05:14, VBatt start/end: 12.3V/12.2V)-----------
-Replaced n75 valve
www.Ross-Tech.com
75 76
Coding: 00001
Shop #: WSC 00066
Coding: 00000
Shop #: WSC 00000
Coding: 03504
Shop #: WSC 00066
Coding: 12345
Shop #: WSC 00066
2 Faults Found:
Coding: 07242
Shop #: WSC 25426
3 Faults Found:
Coding: 00007
Shop #: WSC 00066
1 Fault Found:
Coding: 04096
Shop #: WSC 00066
8 Faults Found:
35-00 - -
Coding: 02041
Shop #: WSC 00066
1 Fault Found:
I'm no pro with VCDS, but it appears to be a low voltage issue all the way around.
I'm pretty sure there are fuses for the ECM and other modules under the hood.
I'm unsure what a battery tender is, but I'll assume you had the new battery tested too...?
Discussion Starter #3
Battery tender is a float charger to maintain a charge(set it and forget it!). I swapped old battery out since it was under warranty but I did not have the brand new battery tested.
As far as fuses under the hood go I’ve yet to locate any others other than the ones that are located directly above battery itself. When I was reading through the scan I kinda put 2 and 2 together since the slow cranking when I’d try to start it and the “supply voltage too low” was coming up.
1 - 3 of 3 Posts
